Where is the map sensor?
Car is a 97 civic(LX)
Anyone know exsactly which is the map sensor? There are 2 plugs on the throttle body, one sits on the rear(closest to the firewall) one sits on the side, directly across from the throttle blade. I think its the one on the rear of the throttle body(closest to the firewall) but would like someone with more civic knowlege than myself to verify.
Thanks in advance!
B
Thanks in advance!
B
Re: Where is the map sensor? (slither)
these pics are just for refrence your throttl body might look a bit different however the map sensor should look the same.
This is the map sensor, if you loook close it shold actually say "map assy" on it.
Its the one on the left, it should have screws holding it on.
hope that helps.
hope that helps.
Thanks man, i figured that was it. Going to be a bitch to install the check valve though, there is a line right in the damn way. arghhhh
Thanks again man
Thanks again man
comptechgsr2000
05-08-2002 03:53 PM
