Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP!
So, i was driving one night with my new turbo set-up just installed the day before.. everything was working fine.. Then for 2 days it was raining from the aftermath of Hurricane Katrina. The next day i go to start up my car, it cranked but didnt start cuz moisture cant into the dizzy and plus i flooded the motor trying to start it. i fixed the problem start it up and NOW my RPM on my stock cluster doesn't work but everything else does.. I swapped my friends cluster and it did the samething. Checked the fuses, wires in the back of cluster.. still nothing.. ANything guys.. HELP!
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP! (petersayarath)
Double check your wires. If your buddies guage was working..
which fuse did u check? mine happened cause of the speed sensor one? i think. rpm went out then speedo then whole car dimmed then battery died. that fuse was the prob to the wholllle thing
id check to see if your speed sensor on yur tranny is ok, might have got water into and jacked it up
I am a (Trial User) Army
Re: Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP! (postman)
Check fuse #15 in the underdash box and check the backup fuse in the engine bay box.
Re: (blackie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackie »</TD></TR><TR><TD CLASS="quote">which fuse did u check? mine happened cause of the speed sensor one? i think. rpm went out then speedo then whole car dimmed then battery died. that fuse was the prob to the wholllle thing</TD></TR></TABLE>
theres a speed sensor fuse? where is that located?
Re: (petersayarath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petersayarath »</TD></TR><TR><TD CLASS="quote">
theres a speed sensor fuse? where is that located?</TD></TR></TABLE>
I didn't know that there was a speed sensor fuse either?
TA Performance
Audio / Security / Video
03-27-2007 06:23 AM
