my car doesnt blow.....
heater, or ac wont work. i changed all relays and fuses and the ****** still doesnt blow.
am i missing anything? i need AC!!!!
thanks guys/
thanks guys/
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (BloodPressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BloodPressure »</TD></TR><TR><TD CLASS="quote">check to see if you have voltage at the compressor, you should have 12 volts. If you do then check your freon.
good luck,
Justin</TD></TR></TABLE>This would be the case if the fan worked but wasn't blowing cold. If I'm reading it right the blower isn't working at all correct? But either way we would need to know what car we are working on so we can help you troubleshoot the entire system. Otherwise we can just give you the general basics..
good luck,
Re: (joon)
i would check into the blower, if you replaced all the fuses that is prolly the case...
check for proper voltage though (dont have correct amount off hand) then see if it is just a bad blower
blower motor is VERY easy to replace or borrow to test. just 3 8mm screws and one plug just inder the glovebox. Should only take 5 mins with no panels to remove.
bxstylez
10-07-2005 05:12 PM
