Zero MPH on Interstate
Ok so I'm goin to NOPI saturday and I look down at the speedo and it says 0 and the cel is on. Get home and pull the codes and it says P0500 Speed Sensor A Malfunction. Could anyone elaborate on which sensor this is and a possible location. Helms manual hasn't come in yet. Thanks
its located just under the intake on the transmission near the rear motor mount. It should eb held in with one 10mm bolt. very easy to get to and easy to replace. hope that helps.
Re: (Manolo)
you can also fill up the tranny oil on thru the VSS, (vehicle speed sensor) for future references
but if u do it that way make sure to measure how much u drained! goodluck getting rid of that CEL
or instead of measuring how much you drained, you can open the drain plug, and pour in new fluid through the VSS hole until it starts leaking out the open drain plug
Re: (Manolo)
follow the upper radiator hose to the engine and that housing is where the thermostat is. To get the housing off you have to take off a few bolt, and there is a wire being held in place by one of the bolts. Thats your ground.
Imperious: Mod of Valor
Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote">^ of all the Speed Sensor questions I have seen on here its good to finally have a picture of it.</TD></TR></TABLE>
Re: Zero MPH on Interstate (BG Performance)
hey i had the same problem and all i did was unplug it and clean it out really good and it worked (saved a trip to honda ) money cost- 0
HGZ
07-09-2006 02:06 AM
Civichatch972
11-04-2003 07:50 AM
