need advice
need advice
OK, I have a 95 dx auto. I want a z6 put in with working vtec with boost and a Stick for godssake. not all of this has to come at once, which is where I run into my problem. The money for the manual swap is no problem, getting the money for the motor/tranny/ecu swap is a little harder. Do I just put the manual on my 1.5 and tune and boost that, then sway the Z6 in later? or is that not worth it? thanks all
Re: need advice (R0ADRAG3)
I would put in the manual trans, because that will work with both motors, then the Z6, then the turbo with tuning. Otherwise you can go Trans, turbo then motor with tune, if you dont care about blowing it up or run with low numbers say 5psi. Someone else help me out here.
If there both D-series motors they should, just make sure you get one out of an Si/Ex. heres a good site for some info about the differnet ones and how to identify them so you dont get scamed.
http://home.cinci.rr.com/mistab0ne/tranny.html
logikalfury
08-17-2005 10:00 PM
