98 civic coupe trunk emblem
Re: 98 civic coupe trunk emblem (TrunkRattlin)
if it's stickied on, use a little heat from a blow dryer and pry it off lightly
i only say use a blow dryer because if you are asking this question, i dont think you can handle a heat gun
Just take some tape and dental floss. Tape around the emblem. Apply the floss between the emblem and trunk. The tape will prevent any damage that might occur. Get the floss near the middle and start yanking away. Should come off fairly easy. I think 2 clips hold the OEM badge on.
Farts in the shower
Don't use a razor you will probably end up scratching the paint.
Make sure its warm as it will be easier to remove, either use the sun or a hair dryer and after its warm use either fishing line or floss and take it off. Then get some goof-off and take the adhesive that is left over and whiola...no more emblem.
carboncivic
12-30-2006 02:05 PM
gutted-dx
10-01-2005 01:44 PM
