99 EK SI -> Loud Squeeking Noise When Starting up the Car. Help!?
1 Post
One of my friends who owns a 99 ek SI wanted me to ask the h-t community about his little problem. Everytime he starts his car, it makes a loud squeeking/screeching noise for a few seconds. If he revs it right away, the noise goes away. We already know it has to do something with the belts.... but is this noise a common problem on the 99+ Si's? Does it mean the belts are too tight or too lose? if so, which one's should he check? Basically, what can he do to make the squeeking stop.
Thanks in Advance everyone!
Re: 99 EK SI -> Loud Squeeking Noise When Starting up the Car. Help!? (iH8RICERZ)
First check to make sure all belts have good tension! Then check to see if they have any age cracks! Have you just changed the belts? IF not i'd say depending on where you are climate wise they may have begun to crack or wear! Honda recommends almost every 90k they be changed unless they fail sooner! But for the most part they last that long!
1 Post
Re: (ThefirstPACT)
thanks for the help so far.... so does too much tension on the belt causes it to squeek? I'll have to ask my friend to see when the timing belt was replaced as well as the other belts....
purgat0ry
11
05-22-2011 10:26 AM
