need help wiring my IAT code 10 itr swap
ok here is some back ground i have a itr swap in a 96 hatch i'm throwing two codes 41 and 10 i know what they are and how to fix 41 adding a O2 sensor thats later but right now i'm trying to fix the code 10 could some please help by SHOWING "PICS" which plug it goes to. i know where the sensor is but i don't understand the manuel when it tells me the plug on the ecu. if i confuse any one sorry. but i just want to see where the sensor wires go on the plug connecting to the ecu. because i don't have any wiring connecting at the sensor and i looked for the color wires that i'm suppose to wired to it but nothing. please help. the car is a 96 cx hatch w a 96-98 ex wiring harnness and the engine is a 96 itr w p73 stock ecu
Re: need help wiring my IAT code 10 itr swap (gato5254)
you shouldnt have to have changed any wiring for the iat sensors.
the iat sensors is on the number 2 cylinder intake runner.
Re: need help wiring my IAT code 10 itr swap (Downey)
no i don't have the wires i'm not trying to change them i'm try to put them there. i guess the guy that did my swap poked me in the eye but he didn't hook it up, he cut some wires and just left a mess. i fixed most of them but i don't know where to wire the iat sensor to the ecu. i think it's called the ecu plugs i just need to know which one to wire it to. it know it's two wires but i can find them in the engine bay so i think it would be easier to just route new wires to the sensor
ok one plugs to connector D pin 8 but where does the other one go it has two
got it thanks man
http://www.ff-squad.com/technet/wiring.obd2a.htm
Modified by gato5254 at 12:08 AM 10/25/2005
got it thanks man
the IAT for obd-2a/b 96+ cars is located on the intake arm, rigth before the trottle body. its the wire that splits from the map sensor one. hope that help, you dont need to plug anything up on the manifold's IAT. at least thats what i did
Waachback
12-02-2003 06:56 PM
