My idle is perfect but when i hold the revs at 1500rpms car starts to....
hey when i start the car the idle is fine, my only cel is 10 and 14, when i hold the revs at 1500 the revs then begin to drop and rise, in a bouncing motion between 1000-2000, if i go above that and just drive its fine
but if i hold the revs at any rpm it does that same bouncing crap
any suggestions could it be my cel's?
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (littleredcivic)
b16 motor in a hatch ihe recent change is that i just swapped the motor in
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (bboylito)
you have the plugs pluged up wrong.. Try putting the IAC plug on the IAT and vice versa
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (ramtyper19)
yea i tried that and when i switch the iat plugs my idle goes crazy, cant even drive the car soon as i press the throttle the car shuts off
happened to me too. take your IACV off and spray the mesh with carb cleaner, let it dry out, put it back on and reset your ecu
What's the setup?
We'll need something more than this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote">b16 motor in a hatch ihe recent change is that i just swapped the motor in</TD></TR></TABLE>
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (EE_Chris)
lol what more do u need to know about the setup, its a completely stock b16, as in injectors manifold, everything, it is using the civic si sohc vtec harness,
thanks for any help
thanks for any help
I had a similar problem on a different engine(sohc). I replaced the IACV and it solved the problem.
Modified by carbonk20 at 7:23 PM 3/15/2006
what ecu are you using?
is it chipped?
does it happen under light throttle only? : less than 5%
my guess if you've checked everything else that your possibly using a p28 and that its bad.
try another ecu if you can.
EDIT: also give me the colors of what you have plugged up where, and ill double check to make sure its connected right.
clean out the iacv, swap one out if you can to check.
is it chipped?
Re: My idle is perfect but when i hold the revs at 1500rpms car starts to.... (IVI)
p30 chipped with uberdata, on a stock gsr map
yes only happens under light throttle, once i'm passed 2000 rpms the car drives fine
i have not tried another ecu, but i have tried another chip and it has the same problem, maybe i should try another ecu
i'll name the colors in a second, and i'll try cleaning out the iacv
thanks for all the hlp and suggestions, honda-tech at its best
One problem might be the fact that you're running GS-R maps on a B16. When you tried another chip, did it also have GS-R maps on it? Have you tried a stock P30?
maps shouldnt matter. that wouldnt cause a signifigant problem like that.
ive run gsr maps, even a sohc d16 map on a jdm b16 with no problems.
im willing to bet alot that its the ecu itself. its probably shot.
try another one when you can. any ecu will do, doesnt have to be for ur motor.
intenseEK
04-13-2009 07:13 AM
