replacing suspension bolts
i'm replacing the 2 bolts holding the damper fork to the strut and the control arm in the front and the 3 holding the LCA on in the rear, so 10 alltogether, but i'm not sure what grade bolts these are. I'm assuming 9 or 10? I'm going to a local shop that makes nuts and bolts for like 50 cents a piece rather than the dealer. So are all these bolts the same Grade? I can't seem to find it in my Helms, jsut says thread pitch, doesn't say how long they are either
Re: replacing suspension bolts (Civicse)
I wouldn't use anything less than grade 8 when it comes to suspension components. The only thing you could really do is take the bolts out and take them to the shop to get them made exactly the same.
Re: replacing suspension bolts (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">I wouldn't use anything less than grade 8 when it comes to suspension components. The only thing you could really do is take the bolts out and take them to the shop to get them made exactly the same. </TD></TR></TABLE>
thx for the info, how much will honda charge per bolt anyway? anyone know?
I would just break down and buy the OEM bolts. check this thread, John Eagle Honda sells OEM parts at employee prices. holler at Gabe in parts and he'll hook you up
as far as pricing, it all depends on the bolt. I had to buy a few suspension bolts for my car, ranging from $5-$15 retail, but like I said john eagle cuts like 50% off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">thx for the info, how much will honda charge per bolt anyway? anyone know?</TD></TR></TABLE>
I would suggest you just go threw honda. They will charge a little more but you will know you got the exact bolt that you need. I've bought a quite a few suspension bolts from them, and it's no more than $3 for any of them.
I would suggest you just go threw honda. They will charge a little more but you will know you got the exact bolt that you need. I've bought a quite a few suspension bolts from them, and it's no more than $3 for any of them.</TD></TR></TABLE>
oh well thats not to bad at all, i'll go through them then, that way i won't need to measure all the lengths and crap, thx for the info
$3 for all bolts is inaccurate. wait till you get there, I just went through my rounds with the suspension bolts like two weeks ago. but good luck
1 Post
use OE honda. i changed out all my bolts when i did my bushings and i think it totaled to about 120 or thereabouts. it made everything look real nice and it all went it easily.
Re: replacing suspension bolts (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">$3 for all bolts is inaccurate. wait till you get there, I just went through my rounds with the suspension bolts like two weeks ago. but good luck</TD></TR></TABLE>
Yes, for all the bolts. But the ones I did have to buy weren't more than $3. If you get into the HUGE *** bolts then they will be pretty pricey.
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">use OE honda. i changed out all my bolts when i did my bushings and i think it totaled to about 120 or thereabouts. it made everything look real nice and it all went it easily.</TD></TR></TABLE>
120? for how many bolts? I'm going to need 8 10*1.25 and 2 12*1.25 and 2 lock nuts
Re: (Civicse)
OEM PN | Item Desc | Qty Needed/Car | Retail Px
For the FRONT LCA/Damper Fork...
90118-S04-000 | BOLT, FLANGE (14X83) | 2 | $8.62 ----- LCA/Frame Bolt
90120-SB0-003 | BOLT, RR.*** SHOCK ABSORBER LOCK (10X42) | 2 | $0.92 ----- Damper Pinch Bolt
90183-SH3-000 | BOLT, FLANGE (12X115) | 2 | $8.12 ----- LCA/Damper Fork Bolt
90215-SB0-003 | NUT, SELF-LOCK (12MM) (SATO RASHI) | 2 | $1.15 ----- LCA/Damper Fork Bolt Nut
*** - I know it says RR... This is what came up for the 1999 Civic SI Chassis/Front Lower Arm listing...
For the REAR LCA...
90173-SR3-003 | BOLT, ARM TORQUE (LOWER) (10X80) | 4 | $7.40 ----- LCA/TA Bolt
90002-S10-000 | NUT, FLANGE (10MM) | 2 | $2.07 ----- Swaybar Link/LCA nut
For the Rear Shock Absorber...
90173-SR3-003 | BOLT, ARM TORQUE (LOWER) (10X80) | 2 | $7.40 ----- LCA/Shock Absorber Bolt
In addition to these, there are a number of smaller bolts for things like Brake Hose Brackets, Parking Brake Bolts, etc...
These are retail prices, for EACH bolt... About $85 as listed for these brand new suspension bolts for your car. There are definitely cheaper OEM prices available if you do some digging. You'll likely save about $20-30 if you get them at http://hondapartsdeals.com ... Don't forget your "honda-tech10" coupon for an extra $10 off! Also, try the John Eagle Honda route for a quote.
Notice that these bolts have a fluted shaft, and that the threading doesn't start until around the midpoint of the shaft. They are Grade 10...
Here are some pics of the Rear UCA/TA Bolt...
http://img514.imageshack.us/im...d.jpg
http://img514.imageshack.us/im...t.jpg
http://img514.imageshack.us/im...g.jpg
I don't think they have these at any hardware stores... Let us know if you find otherwise...
JasonGhostz
BTW... What YMMDTETO (Year, Make, Model, Doors, Trim, Emissions, Tranny, Options) for your ride???
For the REAR LCA...
JasonGhostz
Re: (JasonGhostz)
nice info man thx, does that site ship to canada? doesn't show it on their site, i have a 4dr civic se, manual trans, ej8
1 Post
i changed every single bolt that was suspension related. my car is an alaskan car, so the conditions were tough. the rear has a compensator arm, upper control, lower control, trailing arm, and toe adjustment box. the bolts that correspond with those locations were replaced. the front has the lower control , upper control, and strut fork. the small ones are not too bad. it is the big ones that costed money. make sure you put a good amount of anti-seize on all the bolts so they will come back out later. clean off any rust or other corrsosion before you stick the bolts back in their locations.
Re: (Civicse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">nice info man thx, does that site ship to canada? doesn't show it on their site, i have a 4dr civic se, manual trans, ej8</TD></TR></TABLE>
Ooooooh... Didn't see your loc...
These guys ship from Rhode Island, US. From the looks of things, it shouldn't be any more difficult to get your stuff than if you lived in Detroit, but the border crossing might be a logistical hangup.
I say email/call them up. They have a great cust svc dept, and I'm sure if you explain how close you are to Detroit, they'll be willing to work something out for you. If they give you the finger, it'll be a disappointing surprise to me...
What year, and what is the USDM equivalent of "SE"? For 96-00 Civics, the Helm manual only shows the CDM 00 Hatchback as the only one with an "SE" Vehicle Grade, and it shows "EJ6" for the Line/Body/Engine Type...
(edit: after reading the sig...)
CDM 2000 4DR, huh? Hmmmmm... Well, the bolts should be the same...
JasonGhostz
Modified by JasonGhostz at 7:22 PM 12/20/2005
JasonGhostz
Re: (Civicse)
Right on... I still recommend giving the HPD.com guys a call to see what they might be able to do for you in the future. They have the cheapest (year-round) prices available, and nearly every single part came packaged in a Genuine Honda bag/box with the PN displayed.
Hardware is usually well-stocked at Dealerships... As long as you don't ask for T-50 Torx Head Flange Bolts and 15/16" Nyloc Nuts...
Let us know how things go!
JasonGhostz
JasonGhostz
mikej94civex
06-25-2010 05:21 AM
quest4boost
10
11-29-2006 05:56 PM
Chris_
15
06-20-2002 01:17 PM
