my car is farting...
Old 12-19-2005, 10:02 AM
idriveadelsol7's Avatar
Default my car is farting...
Ok… here’s the noise I’m getting out of my exhaust. my car is farting “puh puh”. Everything is bone stock on this car. It happens frequently when it’s cold, and than once ever other second when it’s operating temperature.
Old 12-19-2005, 10:03 AM
dohcVTECeg2's Avatar
Default Re: my car is farting... (idriveadelsol7)
stop feeding her beans
Old 12-19-2005, 10:09 AM
boysnightout's Avatar
Default Re: my car is farting... (dohcVTECeg2)
my guess is you might have an exhaust leak
Old 12-19-2005, 10:10 AM
Slow EJ8's Avatar
Default Re: my car is farting... (boysnightout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boysnightout &raquo;</TD></TR><TR><TD CLASS="quote">my guess is you might have an exhaust leak</TD></TR></TABLE>
I second that.
Old 12-19-2005, 10:17 AM
Farmer Brown's Avatar
Or the start of a hole somewhere.
Maybe some Bean-o might help.
Or it could be a small missfire too. since you said it happens when it reaches temperature. Yea, that sounds more likely.
Old 12-19-2005, 10:23 AM
it's not an exhaust leak. i've checked every possible point of connection and burnt my hands 2 many times for it to be an air leak.
Old 12-19-2005, 10:24 AM
Default Re: my car is farting... (Crazy Taco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazy Taco &raquo;</TD></TR><TR><TD CLASS="quote">
misfire...? elaborate
Old 12-19-2005, 10:25 AM
acydphryck's Avatar
might be a bad ignition thing or something...
Old 12-19-2005, 10:32 AM
Default Re: my car is farting... (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck &raquo;</TD></TR><TR><TD CLASS="quote">might be a bad ignition thing or something... </TD></TR></TABLE>
my timing is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">
instead of all the combustion happening in the engine, some of it escapes and happens in the exhaust pipe...i think..</TD></TR></TABLE>
how to check? what to check?
Old 12-19-2005, 12:39 PM
97spooncivic's Avatar
by farting do you perhaps mean backfire, i dont understand your onomonapia puh puh
Old 12-19-2005, 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">by farting do you perhaps mean backfire, i dont understand your onomonapia puh puh </TD></TR></TABLE>" it's like not an typical fart noise. like this... "pauh....puah....puah...."
Old 12-19-2005, 12:50 PM
ej0513's Avatar
is it pretty quiet? can you hear it from inside the car?
Old 12-19-2005, 01:02 PM
Default Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 &raquo;</TD></TR><TR><TD CLASS="quote">is it pretty quiet? can you hear it from inside the car?</TD></TR></TABLE>
yeah... it's louder outside than inside. my car drops in idle the same time that noise hits. i recently adjust my engine valves but i doubt this was the case because it happened before touched the valves. now it's just louder.
Old 12-19-2005, 03:17 PM
Default Re: (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah... it's louder outside than inside. my car drops in idle the same time that noise hits. i recently adjust my engine valves but i doubt this was the case because it happened before touched the valves. now it's just louder.</TD></TR></TABLE>
Yea thats sounds like a missfire. Not really serrious when its idling, just annoying. Some cars eventually just do that and can be hard to fix. Sometimes you just need new plugs.
Old 12-19-2005, 03:53 PM
1995Ex_Sedan's Avatar
I had the same exact problem, it ran great, but starting off from a red light, or just during odd times, it'd do the same thing.
Plugs and wires, I'd recommend.
Old 12-19-2005, 03:57 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">" it's like not an typical fart noise. like this... "pauh....puah....puah...."</TD></TR></TABLE>
omg that hilarious, haha
Old 12-19-2005, 04:02 PM
west nile's Avatar
Default Re: (Tippyman98)
does it smell?
Old 12-19-2005, 04:09 PM
Mwsol's Avatar
Default Re: (west nile)
What kind of exhaust do you have?
If you have a straight pipe this sound would be normal. No resonator or cat will cause the "puh" sound. Usually the sound will be like a puh phpuh ... lil silence... puh...
Thats what I know, if you do not have a straight pipe then I dunno.
Old 12-19-2005, 04:33 PM
Spinnbait's Avatar
Default Re: (Mwsol)
That sounds similar to a noise that I heard after I installed my msd system. Though you may not have a msd, try some heli-core ignition wires. They are a little pricey at about $80 for the msd wires, but even if it does not fix the problem you'll be upgrading to some better equipment.
Old 12-19-2005, 05:24 PM
MikeD718's Avatar
Default Re: (Spinnbait)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">I had the same exact problem, it ran great, but starting off from a red light, or just during odd times, it'd do the same thing.
Plugs and wires, I'd recommend.</TD></TR></TABLE>
thats what i would say, my hatch did that and i cahnged my plug wires and got rid of it.
Old 12-19-2005, 06:02 PM
Default Re: (MikeD718)
imma go get me some new plugs right now... just 2 test it out. i have wires on the way. my car is bone stock. cat and all still there.... new distributor.
Old 12-19-2005, 06:25 PM
mountaindewguy's Avatar
check your plug wires for corrosion or rounded spots in the rubber where it should be an edge, or cracks, etc... if they look old/worn out, they USUALLY are not good.
and take the plugs out and check em out...
Old 12-20-2005, 06:04 AM
Default Re: (mountaindewguy)
new plugs and wires are good... =/
Old 12-20-2005, 06:09 AM
Slowboy!'s Avatar
start with new plugs and make sure your on time. Some times if you hit a good bump or jolt the car, sounds crazy but that can mess with timing, dont ask me why.
Curt
Old 12-20-2005, 06:14 AM
I am a (Trial User) Army
litterbox's Avatar
Default Re: (CleanGreen)
That's hilarious, rofl.
asergioc
08-23-2007 12:06 PM
june_si
12-05-2006 08:00 PM
CRISIS
15
01-05-2006 07:40 AM
filipevti
09-09-2005 08:17 AM
IntegraBoy04
10-01-2003 06:46 PM
Quick Reply: my car is farting...
