Fan Switch
Fan Switch
Reading other peoples threads are confusing me. I just want to know how i can run a fan switch on my car when the vehicle turns on. Should i run it with a inline fuse and would a 15a fuse? Would the coolin fan relay need to be used?
Re: Fan Switch (shooitslinh)
Tried to make install a fan switch today. I bought a universal relay but there are 5 pins on them and they are postive,negative, fuse, and two lamps. Everything has power to it. My question is am i wiring it correctly? Do the two lamp pins go to the fan. Where should i wire my fuse pin? And am i supposet to fuse it.
you dont need a relay to wire up a switch for the fan. at least i didnt. i'm just using the factory fuse for the fan. if no one beats me to it, i'll post up again saying how. at work, will post up later.
