93 dx to 94 ex conversion!
Ok I'm new here so bare with me. I'm in the middle of doing an interior swap from from a 94 ex coupe to a 93 dx coupe. And I have a couple questions. First off I swapped the doors so the interior panels would match up fine and because I wanted power windows for a daily driver. I already cut the wire harness that connects to the outside of the door and have the wires ran into the car, I need to know where to connect them to get power windows, locks, and mirrors working. The windows are essential but, the other two aren't totally necessary for me. My other big issue is the 94 dash has the passenger airbag. I have the wire harness from the other car so I guess it would hook up to the SRS computer and work. But, the big problem is the weight of the damn thing. I have the tubular support bar for the dash that mounts to the exhaust tunnel north of the shifter, but I noticed the 94 also had two brackets that came out right under the windshield that helped support it too. Think it will hold up ok with just the support tube installed, or should I just remove the damn thing all together? Any help would be GREATLY appreciated!
Re: 93 dx to 94 ex conversion! (e.g.meep)
BUMP! :\...... I did some searching and can probably take care of the power window situation. Though, most of the stuff I see isn't for a whole door swap but just the components inside the door instead. Still not to sure about the airbag, those aftermarket trays are cool, but for a daily driver, protection is good too.
what's up, i did this same conversion that your working on but your doing it the hard way. what you need for power options to work is the main interior harness,thatis behind the dash. it runs from the drivers door to the fuse box,up to the steering column,back behind the dash over to the ecu and to the passenger side door and out to the fire wall to the motor.and you can use the same dash.if you have any more question email me @jordan2305@***.net
VTEC IS UR BEST FRIEND
03-22-2010 06:45 AM
put ex coupe doors with power windows want to make them work in my dx do i need harness from the doo
flatblk
11-04-2006 08:54 PM
B18B1_4DR
10-09-2006 11:31 AM
