92-95 EG swap guru's help needed
Very embarrassing quick question guys....will 94+ Integra Hatch, not sedan, mid-pipes fit an EG hatch?
YES, I USED the "search" function @ great length....ANY help appreciated.
Re: 92-95 EG swap guru's help needed (1250b18c5)
mid piping will fit sort of. you might have to trim either end. i suggest just getting custom mendrel bent piping done. cheaper and faster then trying to fabricate your own.
Re: 92-95 EG swap guru's help needed (wob)
not true, trimming might have to occur. not sure if it was gsr or itr. the axelback will definately need trimming or it will stick out 6-8"
Re: 92-95 EG swap guru's help needed (CALIdelsolSIR)
Nope on my eh2 I ended up using the original greddy evo piping from my dc its exactly the same as the 92-95 civic 3dr piping coulding use the axle back tho it sticks out wayy to far.. Had 2 add a little after the header tho coz it wouldn't reach ..ls swap
376R
04-13-2005 04:12 PM
