Brightest Headlights??? Pictures would help
I drive alot at night and I was wondering what is the best headlight for the job? I dont care about blinding the oncoming cars because there is few and far between here. I want something that will light up the road and I cant out drive them. And tell me how hard the install was. I have those super blue/white bulbs there like 160/190 and the light just scatters.
Thanks so much for you help.
Forget the stock looking bulbs... if you want something bright, then you will need to go with HID's You can get a kit for like $300, i know thats a lot, but trust me, its worth it.
Re: (gmacarize)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmacarize »</TD></TR><TR><TD CLASS="quote">Forget the stock looking bulbs... if you want something bright, then you will need to go with HID's You can get a kit for like $300, i know thats a lot, but trust me, its worth it.</TD></TR></TABLE>
that and getting some Fog lights will help as well.
Re: Brightest Headlights??? Pictures would help (Hump-Free)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hump-Free »</TD></TR><TR><TD CLASS="quote"> I dont care about blinding the oncoming cars </TD></TR></TABLE>
i hate ******s like u, u ppl make me wana get outa my car and beat the living **** out of u... good day.
Re: (HondaEJ7)
if u want the most out of your HID's, u gonna have to retrofut some projectors to your housings. if not, your gonna have tons of ugly glare. not to mention it won't illuminate the road very well.
Re: (futurefastguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futurefastguy »</TD></TR><TR><TD CLASS="quote">if u want the most out of your HID's, u gonna have to retrofut some projectors to your housings. if not, your gonna have tons of ugly glare. not to mention it won't illuminate the road very well.</TD></TR></TABLE>
well said. you can drop $300 for a kit but putting HID in a housing made for halogen will glare everywhere and will suck ***, you will lose more light than you can produce. you might as well use stock halogen bulbs. if you want bright you have to pay high, your best option and only option is HID RETRO. other wise use sylvania silverstars or OEM bulbs. those are the only halogen bulbs that put out the highest lumens(light output).
Re: Brightest Headlights??? Pictures would help (hitvtecgetloud09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">
i hate ******s like u, u ppl make me wana get outa my car and beat the living **** out of u... good day.</TD></TR></TABLE>
+1
+1
Re: Brightest Headlights??? Pictures would help (Purpl3Haz3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purpl3Haz3 »</TD></TR><TR><TD CLASS="quote">get an hid kit...20 minute install...22 minutes if u dont know what ur doing...they go from $300 to whatever</TD></TR></TABLE>
For a shitty drop in kit, yes, 20 minutes. For a good retrofit like you should be doing, you're looking at closer to a day.
Darth ModerVader
Re: (HondaEJ7)
If you're looking for HID retrofit components, try HID Planet.
If you want high-performance replacement halogen bulbs, choose a set of Philips Vision Plus from Autolamps Online
Re: (HondaEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 »</TD></TR><TR><TD CLASS="quote">not tryin to hijack, but where would u get a GOOD kit from thats not just drop in? i wouldnt wanna spend 300 to get glare</TD></TR></TABLE>
Ebay. BMW bi-xenons with the shrouds, bulbs, ballasts, ignitors and projectors go for 300-350 on there pretty often.
a jdm headlight housing will not help. only way i can think it might help is the jdm housing are made of plastics instead of glass, so if the plastic is clear and new enough it might help. but otherthan that, it was made the same spec i believe.
retrofitting is somewhat hard if you never tried it before. but its not hard to learn, a good amount to learn and know before you do one but its not that hard. just a bit on the time consuming and creativity
HT Order of Merit
Re: (central_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by central_driver »</TD></TR><TR><TD CLASS="quote">if u dotn wanna spend 300-400bucks on a HID kit. buy some PIAA GT-X Bulbs. there about 65-70bucks online and are badass
PIAA headlight bulbs tend to get VERY hot in the housing and blow out. And 80$ a pair is not what i would like to spend every 6 months.
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">i hate ******s like u, u ppl make me wana get outa my car and beat the living **** out of u... good day.</TD></TR></TABLE>
+2
+2
#1 Super Guy
Re: (mwieczorek43)
FYI: JDM headlights are designed for driving on the left side of the road. OEM headlights have an angled cut-off that is designed to shine light further out onto the shoulder of the road to illuminate signs & pedestrians. If you use them on US roads, the angled cut-off will be shinning your headlights right into oncomming traffic all the time...
if you want to stay with the stock housing. PIAA or Silverstars are the way to go. I've had my set of PIAA Xtreme bulbs for well over a year now with no problems. (I know I've jinxed myself now)
You can also install a headlight relay harness to get rid of the voltage loss of the civic's wiring harness. It does make a difference and it only costs you a few wires and a couple relays.
An HID retrofit is by far the best way to go. But not simple nor cheap.
* B A N N E D *
Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">FYI: JDM headlights are designed for driving on the left side of the road. OEM headlights have an angled cut-off that is designed to shine light further out onto the shoulder of the road to illuminate signs & pedestrians. If you use them on US roads, the angled cut-off will be shinning your headlights right into oncomming traffic all the time...</TD></TR></TABLE>
I guess re-aiming your headlights will solve?
HT Order of Merit
Re: (Relic1)
I never knew that...
