Car won't Crank ---Please Read---
Obd II Gsr motor with Obd I Ecu...
93 Civic Ex
Symptoms, Car will not crank battery is charged and fine, tried replacing the starter still the same results.. the motor itself is fine because the car starts when push started...checked all the fuses. .. is there anything else to check I'm really in ah jam here with this being my only transportation
any input, opinions, etc. etc. would be greatly appreciated
93 Civic Ex
Re: Car won't Crank ---Please Read--- (QUICKERSILV3R)
what does it do when you try to start it? does it turn over, just hear clicking, nothing, etc? can you hear your fuel pump prime? If it turns over, can you smell gas by the fuel rail after trying to start it?
Re: Car won't Crank ---Please Read--- (IHateJDM)
doen't crank or turn over at all. It does make a click if your standing right next to the battery, its a very slight click not loud like when your batteries dead, I just read that it could be the clutch signal that could have gone..
how do you know your battery is good? try it in another car, or test it at autozone? sometimes it'll have enough power to run the interior lights and radio, but not enough to crank the car.
for the clutch switch, look under the dash by the top of the clutch pedal, and you'll see a switch with 2 wires going to it. Jump those wires together, and you bypass that switch.
deftones0817
07-14-2005 08:17 AM
