What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX
I just put my B16A in yesterday and need to get an AC bracket to fit. I also need to get the timing belt for it. Do I get a belt for a US 99 SI? One honda dealer said that they have seen issues with those because of differences in teeth with the JDM motor. I will probably just get the number off the belt tomorrow and try looking it up with that. Anyone know the correct belt to use or what bracket for the AC?
I also would like to thank http://www.hmotorsonline.com for the engine. I will only buy motors from them. I got everything in perfect condition, even sent brand new axles.
Re: What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX (eargsm1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eargsm1 »</TD></TR><TR><TD CLASS="quote">I just put my B16A in yesterday and need to get an AC bracket to fit. I also need to get the timing belt for it. Do I get a belt for a US 99 SI? </TD></TR></TABLE>
Yes, you can use the 99SI belts.
Is there any difference in the belt on the JDM, I don't see why it would be different. It is the same motor! Do you know what Bracket to use to keep the AC?
If your using the d seires compressor then get the ac bracket for a 97 CRV, its about $70-$80 from honda ( cheaper than del sol bracket) and it will directly bolt up to your b16 and all 4 bolts on the compressor will bolt up. I used this on my b16 swap.
reydio
09-26-2006 10:06 AM
90civichbsi
08-10-2006 11:45 AM
