quick obd2 to obd1 p28 question, missing at startup, rich
wanted to run a stock p28 on my 96 because the cat;s gone, car still does run good on obd2, but the obd1 feels smoother and better
at startup, it misses and wont idle, like my teg after putting a big str TB on it with out the secondary idle thing on the bottom.
after warming, its fine and drives great. you guys think its a TB issue? and a obd1 with coolant flowing through will help?
Any codes? I'm guessing not, but hell, ya never know. Did you ***** with the ect compensation or anything like that that would affect not normal operating temperatures?
Re: (SVOboy)
i ran both a stock p28 and a chipped p28 running a stock program. thought it was the harness( freind made it) but it runs fine after warm. acts just like my built integra, at startup its lumpy and rich, and if i lean it out in crome, it idles lean after warm, so i live with it, although i'd like to clear it up.(this started after getting a 74mm str TB on there)
i cant have this on teh 96 ex, its the dailey car
Does leaning out the warm up help on the teg? You can always just lean out the warm up part in the advanced tables part of crome. It must be something acting crummy with a sensor. Try unplugging **** and seeing how it affects things. That's part of how I discovered my iacv problem.
Re: (SVOboy)
it did a little, but like i said, i seen it leaning out after warm up.
as soon as the teg is started, it goes to 750 and trys to idle, it wont idle up when cold liek it used to with the factory bored out TB
Re: (SVOboy)
it was there before, i remember it, i'll go DL the newest one. appreciate the crome tips and all,
but still havent figured out were to start on the 96 car with a stock p28
Well, that's what I thought I was talking about? Is this a del sol with an obd2 p28?
I'm slightly confused why the ecu would create such a problem just from going obd2 to obd1, hopefully someone can give a reason why and a fix.
Re: (SVOboy)
lol, we got to talking about my 95 gsr on crome,
the 96 has a obd1 conv harness and a stock p28 in it, it misses and is smells rich when 1st started..lol
jdm_vtec
09-06-2007 11:12 AM
