fixing a 95 ex crash
ok so i had a crash in my ex today and took off the bumper that was cracked. oppon removal there was a Black metal( bumper mounts to it in a way by lights) bar about the size of a 2 x 4 bent so i pulled it out with a rope but i was wondering if i could remove this and get a new one? also how do i take it out? i found 4 bolts but can take them out beacuse 2 are in a odd angle.
justin
justin
Re: fixing a 95 ex crash (doggworld1233)
are you talking about the actual bumper?
I've never taken one off but I'm sure you can take it off and replace it with a new one
Is it making your bumper sit bad or what?
Re: fixing a 95 ex crash (Soccerking3000)
The part you're refering to is what we call a re-bar. Just remove the four bolts(you may need air) and it'll drop right off.
Re: fixing a 95 ex crash (93gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 »</TD></TR><TR><TD CLASS="quote">i am talking about the black metel thing with a dent in it. it looks like a 2 x 4. </TD></TR></TABLE>
that would be your actual bumper, the plastic "bumper" is just the bumper cover as that adds no protection
as to your question, id pull it off and just replace it from a junkyard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe »</TD></TR><TR><TD CLASS="quote">The part you're refering to is what we call a re-bar. Just remove the four bolts(you may need air) and it'll drop right off.</TD></TR></TABLE>
no its the bumper, the plastic/urethane most people call the bumper is actually called the bumper cover.
ok so i have a prob i can only get 2 bolts off the other two are behind a plate that is all fucked up on both sides. any ideas how to get it off? also the bumper cover is cracked can i fix it ?? and what is the price for a new oem one(from honda)
Re: (doggworld1233)
there shouldnt be anything covering them, therewould have been 2 plastic pieces (one on each side) covering one of the holes but those just pull out...
Look guys, I work at a body shop, the metal black bar is the bumper reinforcement bar (re-bar), the plastic piece is the bumper cover, and theres also usually an abosorber thats styrofoam(between the cover and the re-bar).
it doesnt matter if you work at a bodyshop, its the bumper cover or bumper face, and the beam underneath is the actual bumper/bumper beam
http://www.hondaautomotivepart...UMPER
by what your saying there are things that surround a non-existant piece on the front of the car...
Re: (doggworld1233)
cut a hole or bend the metal so u can get to the screws and remove it.
heres a better pic of what your talking about. on this site its called front reinforcement.
Re: (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">cut a hole or bend the metal so u can get to the screws and remove it.
heres a better pic of what your talking about. on this site its called front reinforcement.</TD></TR></TABLE>
Thanks john666
Thanks john666
Re: (doggworld1233)
Damn homie, try reading people's replies. It's BOLT on.
You don't need one. The purpose of that bar is to minimize $$$ damage on low speed collisions, typically driver's errors when parking.
Re: (suspendedHatch)
ummm they are kinda important. They also connect at the ends of the wanna be frame. the rad support helps some but this also strengthens the front end of the frame.
Re: (doublejz)
Dude, you def should have the re-bar on there (kind of a safety issue) and it protects your radiator as well. Like doublejz said, the only thing behind it is the rad support, and its in your best interest to not damage that (costs more to repair).
2ksilverex
10
04-27-2004 06:19 PM
DJ Rub-ISH
10-20-2003 11:43 PM
