can't find anything on tranny flushing.
how do you do a tranny flush on a manual 94 Dx? and what oil should be used? what tools would i need? pictures would be nice. i searched and couldn't find anything on this, weird.
Re: can't find anything on tranny flushing. (cyang08)
Do you need instructions to change your motor oil?
There is a plug on the side of the transmission, you just pull that out and drain the fluid. There is another plug up higher that is the fill. You can either add fluid there, or add it thru the VSS. Either way, you need to fill to the bottom side of the fill hole.
This is why, when you work on your own car, the first purchase you make should be a repair manual.
Re: can't find anything on tranny flushing. (Marauder)
https://honda-tech.com/zerothread?id=382416
https://honda-tech.com/zerothread?id=1578523
It should be done while the tranny is warm.... like 10 min drive warm...
lonefuzzy79
04-30-2002 07:51 PM
