Swaped 99ex cam into 93ex motor.
Whats going on, I just got done swapping the cams, the reason behind this is that the 98-2000 cams had a higher valve lift on the intake side, same as stock on the exhaust side. But when i took it for a drive today, I hit 6000 rpms and seems to die. Alot more power from 3200-6000. But still have up to 7200rpms on the block. I think I might be running lean at 6k. But injector sizes or the same for 93-99 ex. Hav'nt got the timing perfect yet with a timing lite thats tomorrows job. but anyone think anything about the dead spot.
Re: Swaped 99ex cam into 93ex motor. (intelB16A)
the cam timing will be off like 4.5 degrees. The D16Y motors cam gear is offset slightly. I have seen a post on how to fix it but cant seem to find it.
Re: Swaped 99ex cam into 93ex motor. (USDMej1)
using the cam gear off the original cam. Im going to try to look up some numbers and get my timing lite out tomorrow. thanks for the tip ill look into that.
set the timing on the motor today. After the engine was wormed up and i jumped to 2 pin connector, i checked the timing and it was at the 16 degree mark already, so i set it as if there was like another 2-3 lines on the crank pulley. test drove it seems to want to rev harder at high rpms but didn't pass 6500rpm.
