BLOWING FUSES LEFT TO RIGHT
the fuse to the alternator and sp sensor (speed sensor) keep blowing i keep putting in a new fuse yet iono wah the problem is i pull the battery wen the car is started the positive to see if the alternator is bad i guess not well iono if thats a good way to check heard it from a friend then i checked everything still dunno wah the problem is and then before i put a new fuse in i took the speed sensor clip off and put the new fuse in and again it blows the fuse......can anybody help me?
Re: BLOWING FUSES LEFT TO RIGHT (fmrprojects)
Id say check to see if wires are touching metal and also check your ground could be loose or bad connection causing your short to have nowhere to run out too and just stay in your line
RVMIRXZem1
10-26-2018 07:05 PM
x justin
08-15-2006 09:38 AM
