D15 to D16z6 help
D15 to D16z6 help
Hey, I have a 1993 honda civic ex that had a D15 in it, but I just put a d16z6 in. It all went in as planned, but does not start. It will turn over and has spark but it is not getting fuel. I still have the computer in the car from the d15. I know that I need a p28 for the VTEC to work but, didn't know if the car would start without the p28. If the car should start, do you have any other suggestions?? Thanks
Re: D15 to D16z6 help (4DRD16z6)
the car will start with the p06. i ran mine for 2 weeks on a p06
i dont know what your problem could be, but i would make sure everything is plugged in correctly. make sure none of your harnesses are switched around.
i know some around the intake manifold are switchable (but wont work if they are hooked up wrong) map and iac? i think those are the two
slammed_coupe
02-24-2005 05:43 AM
