HELP!!!!!! check clutch fluid!!!
Re: HELP!!!!!! check clutch fluid!!! (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- »</TD></TR><TR><TD CLASS="quote">Put more in....
It's next to your master cyl for your brakes.</TD></TR></TABLE>
I think he's aiming more at...how do you check it...like to see what the level is...
Re: HELP!!!!!! check clutch fluid!!! (BiGcAmBoDiAnSaUsAgE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGcAmBoDiAnSaUsAgE »</TD></TR><TR><TD CLASS="quote">how do u bleed it? hydro!!!!! </TD></TR></TABLE>
Open up the valve, it is by the tranny. Have someone pump the clutch pedal like 3 times and hold the pedal down on the last one. Close the valve and repeat the process until all air bubbles are out.
The bleeder screw is #1 in the diagram:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGcAmBoDiAnSaUsAgE »</TD></TR><TR><TD CLASS="quote">thanx man!!!!!!!! helpful info!!!!!!!</TD></TR></TABLE>
No problem, unless there is a leak this should take care of the problem.
Re: HELP!!!!!! check clutch fluid!!! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Open up the valve, it is by the tranny. Have someone pump the clutch pedal like 3 times and hold the pedal down on the last one. Close the valve and repeat the process until all air bubbles are out. </TD></TR></TABLE>
I thought it was "push push push hold open close release"
Won't having the bleeder open while you're pumping cause it to suck air back into the line?
Re: HELP!!!!!! check clutch fluid!!! (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">
Won't having the bleeder open while you're pumping cause it to suck air back into the line?</TD></TR></TABLE>
You mean push the pedal all the way down, then close all on one pump?
I did it the way I posted and it worked for me, no air in the line and the clutch works fine.
buzlink
10-22-2007 05:25 PM
