Remove Power steering
A friend of mine is going turbo, was wondering what most do to rid a 97ex of power steering? Some people remove everything and just add a loop of hose on the rack. Do most guys run an older model rack?
any suggestion greatly appreciated.
Re: Remove Power steering (Drifte)
also was wondering if a non vtec head would be a better choice. theirs one for sale in our area, and I have heard vtec and turbos dont get along
Don't know about the power steering, but Vtec runs a higher compression ratio and thus making it harder to get the boost right.
running a built block, just wondering about the head though. can i just stick the non vtec head in...or maybe leave the vtec head and unplug the relay etc.
Re: (Drifte)
The non vtec head is optimal for boost in my opinon. unpluging the vtec on the vtec head won't bring the compression ratios down. I would suggest asking around and seeing what success other people have had with different set ups.
New User
have 2 civics right now cx with manual steering and si with power
call me a whatever but i like the power
i would say if it has it leave it if not o well
moderator emeritus
Re: (nello a.)
your rack configuration should be the same as my ludes......
https://honda-tech.com/zerothre...86242
i looped my hoses at the rack.
Re: (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">The non vtec head is optimal for boost in my opinon. unpluging the vtec on the vtec head won't bring the compression ratios down. I would suggest asking around and seeing what success other people have had with different set ups.</TD></TR></TABLE>
Not true. The compression is fine for boost. I run 10:1 C/R for boost.
Re: (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 »</TD></TR><TR><TD CLASS="quote">
Not true. The compression is fine for boost. I run 10:1 C/R for boost.</TD></TR></TABLE>
agreed, 10.6:1 here with 12psi.
BOOSTEd2
10-07-2009 08:10 AM
sonson6
12-11-2007 09:56 AM
