Car smells rich, poor gas milage.
HT White Ops
I have a 99 B18B1 in my 97 CX, and the swap runs great, no codes (other than the infamous code 91). When I get out of my car after I turn it off, I can smell fuel in the exhaust. Plugs were replaced recently (100 miles ago).
What are the most common culprits for this? I'd search, but I'd be a million people with a million problems getting a million different answers. I'd just like it all laid out for me.
TIA.
TIA.
HT White Ops
Re: (JDM_Ej)
I'm going to go check tomorrow. I suppose I should. I keep throwing a code, but I've always thrown a code. Figured it was just the same one popping up again.
Guess I trot on down to Autozone tomorrow
HT White Ops
Re: (WOMENZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOMENZ »</TD></TR><TR><TD CLASS="quote">why dont you go on a shopping spree if it smells so rich</TD></TR></TABLE>
Because you're a ******?
HT White Ops
Went and got the codes read, and no O2 sensor. The only codes it was throwing were P0450 and P0453, wich is just the Code 91 issue (FTP sensor).
Any more sugguestions?
Re: (Eran)
people will tell different things it is dew to obd2 ecu that pick that sensor up easy way or expensive way is geta ob1 ecu which does pick that code up .
i searched may this thread might help some
https://honda-tech.com/zero thread?id=1581107
HT White Ops
Re: (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">How bad is your gas milage? it could be one or more stuck open injectors.</TD></TR></TABLE>
230-260 to a tank with a stock B18B1 in a 97 Civic CX.
Re: (Eran)
bump because i've got a smiliar situation.
It started happening after the header/TB/intake install. Before I was getting ~290miles off 10gals. Now I'm only getting 250-260
But if you think about it that's not too bad for a b18b. Right around the EPA rating.
Re: (Orangedragone)
check and see if you have any leaks in your fuel system. fuel lines are tight, o rings on the injectors are good, etc. and did you replace your fuel filter
B A N N E D
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
230-260 to a tank with a stock B18B1 in a 97 Civic CX.</TD></TR></TABLE>
**** I'm lucky to even see 250 a tank with a sohc.
HT White Ops
Re: (garrettej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrettej8 »</TD></TR><TR><TD CLASS="quote">**** I'm lucky to even see 250 a tank with a sohc.</TD></TR></TABLE>
Damn, what's wrong with your car? When I had my Y7, I got 320 to a tank. In fact, when I was running a stock P06 on my b18 (regardless of the other problems, such as fluxuating cold idle, and loss of power), I ran out of gas at 328.
It's just odd that a stock P75 will net me no more than 260.
HT White Ops
Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">check and see if you have any leaks in your fuel system. fuel lines are tight, o rings on the injectors are good, etc. and did you replace your fuel filter</TD></TR></TABLE>
Hasn't been done in a while. How often should you change your fuel filter? According to Honda, thier fuel filters don't ever need to be changed on any OBD2 cars.
TunerShark
11-02-2006 06:32 PM
93CharcoalHatch
10-22-2005 01:37 PM
