Help Camber Question
Old 10-31-2006, 12:48 AM
wwang924's Avatar
Default Help Camber Question
Here is the situation, I have 17" rims(i know too big), 35 series tires, SRE camber kit, b18b, and eibach pro-kit. The problem is on the right side(front right) I think the previous owner had an accident on that side, I have a positive camber that i can not fix with the SRE camber kit. But the left side is fine. What I am looking for here are suggestions to fix it or what could be the actual problem. THanks.
Old 10-31-2006, 05:23 AM
LowSlow93Sol's Avatar
Default Re: Help Camber Question (wwang924)
Pay money to get the car aligned and checked out.
Old 11-01-2006, 05:07 PM
wwang924's Avatar
Default Re: Help Camber Question (LowSlow93Sol)
Ok I was dreading that, but I think that is what i am going to have to do. Does anyone know about how much that usually costs? And is there like a specific thing I should tell the shop when i take it in? THanks.
Old 11-01-2006, 06:46 PM
New User
williejohnson's Avatar
i have 17" rims 35 series tires eibach pro-kit plus some other things does your ride hurt your back cause mine shure does
i used to work at a body shop and i would say your frame might be bent i would have a shop put it on a frame rack and measure everything out if it is bent theres no way you will ever get an alignment
frame time is like 50-70 an hour and set up and measure pays 2 hours so like $100-$140 4 wheel alignent sould be like 50
Old 11-08-2006, 10:57 PM
wwang924's Avatar
Default Re: Help Camber Question (williejohnson)
My ride doesn't hurt my back, I ahve AGX's maybe that helps a little. So overall you're saying about 200 dollars to get my problem fixed right?
Old 11-08-2006, 11:03 PM
nighttrain33's Avatar
If it is just an alignment, you should be looking at between $50 and $100, depending on where you go. When I had to get one done, it cost me $75 or so, and that was at a local place.
And like williejohnson said, if it's the frame, then it will dramatically rise from the alignment price.
-Shane
Old 11-08-2006, 11:08 PM
Also, I would think that if the camber on that side is too much to correct with a camber kit, that it would either be the frame or that maybe the car is lowered too much. But, I am assuming that you know better than to lower the car too much. So in short, I think it's the frame.
-Shane
Old 11-09-2006, 03:51 PM
New User
i have kyb non adjustables and full energy suspension bushing kit so that could be it
yes i am saying aprox $200 should get your frame fixed
good luck
dlx111
04-13-2016 06:49 AM
manchildteggy
Suspension & Brakes
11
06-16-2011 04:42 PM
Don JD
10
09-23-2009 08:04 AM
aznvietboi87
06-11-2006 01:45 AM
$amGD3
12-19-2005 11:50 AM
Quick Reply: Help Camber Question
