what tools do i need?
i am in the process of changing my own head gasket on a b16 eg. what tools do i need?
i am particularly concerned about the removal/installation of the head bolts/studs. is it easy to remove the stock ones?
Re: what tools do i need? (el_toro_de_magnifico)
basically its all bolts and nuts you will need metric sockets and wrenches for. YOU WILL NEED A TORQUE WRENCH! May as well adjust all the valves while your in there so get a vavle clearance guage and do that if you want. not a tough job just a bit tedious. **** luck.
Re: what tools do i need? (951BRO)
all right. so its easy but tedious. well, i need to know which torque wrench type is better.
this?
or this:
the first type is very cheap. can get one locally for less than $10. the other around $25. the first one kinda gives me the feeling that after some use it will lose accuracy.
this?
or this:
second one is better, make sure you always "0" them when not in use as they use a spring.
Also if you have 10 12 14 17 19 you can pretty much take any honda apart
also a pry bar or strong back will help lift the head off the block along with a slotted screwdriver for the valve adjustment. Have a method for removing the crank pulley bolt also, without air tools, you'll likely be fighting a losing battle. A set of pliers for misc hose clamps will also be needed. I'm sure there are a couple i'm forgetting...anyone else plz chime in.
Re: (notfastenough)
why do you need to remove the crank pulley? but yeah your philips and flat screwdriver, pliers, drain pan for coolant etc
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Make sure the sockets you have are 12-point.</TD></TR></TABLE>Why is this? I haven't done this before, and I wanna LEARN, DAMMIT!!! TIA
Re: (JasonGhostz)
because 12 pt will fit all whatever size bolts you are taking out but if you have a 6pt 12mm and its a 12pt 12mm your screwed
Re: (HeikDiesel)
I'm just thinking along the lines of doing a timing belt...it's time for sleep. OK, if doing a timing belt....worry about the crank pulley. My bad
Oh, might want to do an oil change after having all those oil passages open and easily able to catch debris. Just a thought.
I don't think on this job, there are any 12 pt bolts. I say 6 pt especially for someone that isn't the most familiar with weilding tools for less likelyhood of rounding bolts/nuts. 6pt ftw!!
SOHCLUDE6
01-12-2012 06:35 PM
Tong.Y
32
02-01-2011 02:05 PM
eddiecut
13
06-20-2002 05:00 PM
