Built up grease and gunk on my alternator...
When I was changing my tranny fluid today, I noticed that the bottom of my alternator on my EM1 was covered in grease and gunk. Is this normal? It almost looked like caked on axle grease or something.
I wiped all of the gunk off, but could this damage my alternator?? And is this normal or not? Thanks in advance for your help!
Re: Built up grease and gunk on my alternator... (EM-One)
It can if it gets into the stator and the armature. The grease is most likely from a bad CV boot and the grease flys when your going down the road.
Re: Built up grease and gunk on my alternator... (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">It can if it gets into the stator and the armature. The grease is most likely from a bad CV boot and the grease flys when your going down the road.</TD></TR></TABLE>
That's the weird part...my CV boots looked just fine! I didn't see any tears, or any lube around anywhere around there. I did see a buildup of grease in the center of my suspension arm, however, but I couldn't figure out where it came from.
