b20 vtec head
Old 06-24-2007, 03:43 PM
civicb16eg's Avatar
Default b20 vtec head
my friend has a a fully built b16 head that was tapped onto a b20 block... hes trying to put the head onto his GSR block...what needs to be done to the head so it can be compatiable with the gsr block?
Old 06-24-2007, 05:08 PM
gd99em1's Avatar
Default Re: b20 vtec head (civicb16eg)
it should go right on with no problems
just replace all the necessary gaskets
Old 06-24-2007, 06:13 PM
abusedhusband's Avatar
to put that head onto the b20 there should of been a oil hole tapped and plugged on the mating surface of the head,and a fitting for a oil line on the back side of the head behind cylinder four. he will have to unplug the oil hole on the mating surface and remove the adapter four the oil line and plug it. then the head shgould bolt wright on.
Old 06-24-2007, 08:57 PM
civicb16eg's Avatar
Default Re: b20 vtec head (abusedhusband)
thanks bro...ill update after it is done hopefully by this weekend
hybrid_vtec
20
04-21-2010 10:22 AM
gearhead818
03-21-2010 07:48 PM
shotime
07-16-2008 07:38 PM
SuperImport
03-15-2005 08:19 AM
2point0VTEC
11
12-13-2002 04:59 AM
Quick Reply: b20 vtec head
