cluster help
cluster help
i need to buy a new cluster for my car... i have a 93 ex coupe i would like to buy an si cluster or a gsr cluster... what parts do i need besides the cluster itself to make it work?
Ek Forever y0!
Re: cluster help (Midori Green)
If you get a 5th gen cluster if will work fine with your factory wiring.
Plug and play.
I don't think there's much involved in wiring up a gsr cluster, maybe a little re-pinning.
Plug and play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">my mph stay at 0... and my vss is fine so im guessing my cluster is bad right??</TD></TR></TABLE>
Yeah, most likely, the speedometer heads go on clusters, it's not completely uncommon.
It'll work fine, as long as it's the same generation. As far as bolting in though, you'll have to use pipe straps to get the holes to line up, and the bezel won't be 100%, but it's definitely a nice improvement.
This should help ya a lot.
https://honda-tech.com/zerothread?id=1053318
and
http://www.geocities.com/cinq1....html
and
trooper0641
25
04-25-2004 05:44 PM
