Piston rings replacement D16Z6 motor
I am planning of replacing my piston rings on my D16z6 motor.
My questiion is can I remove the piston from the top of my engine block and not from the bottom of the crankshaft.
Thanks.
Thanks.
Re: Piston rings replacement D16Z6 motor (racing27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing27 »</TD></TR><TR><TD CLASS="quote">I am planning of replacing my piston rings on my D16z6 motor.
Thanks.</TD></TR></TABLE>Yes, thats how they normally come out. Unbolt the rod caps, and gently push the pistons out from the block. The motor should be out of the car either way, as after the glaze hone is done, the block should be washed.
Re: Piston rings replacement D16Z6 motor (NAisBEST)
Finally someone helpful answer my questions. I thought nobody reads my post. I really appreciate your help. I never done this job before. I might not have to hone the bore and just change the pistons rings and that's it. have you done this job before?
Thanks a lot.
Thanks a lot.
Re: Piston rings replacement D16Z6 motor (Crazydave)
Yes I will also replace the rod bearing, head gasket, valve cover gasket, oil pan gasket and of course piston rings Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing27 »</TD></TR><TR><TD CLASS="quote">does it reallly necessary? how hard is it to hone?</TD></TR></TABLE>
Yes, honing is pretty cheap.
It is necessary, because if it's scathed in any way the rings won't seal right and you'll have blow-by.
Wheelman-CZ
02-05-2007 08:44 AM
