gauge cluster swap question
i just put a 94 si cluster into my 93 cx hatch back. i cant figure out why my fuel gauge says full the whole time. has anyone had this problem before?
Re: gauge cluster swap question (MeGotRoundEye)
Perhaps a broken fuel gauge. Test whether the screws behind the fuel gauge are tight. If the screws are free spinning, then your gauge is toast. If they are tight but your gauge isn't working, then it is toast. Buy a new replacement at Honda for $30-40.
Re: gauge cluster swap question (BlueIntegraBoy)
thank you, i will pull it back out tonight and check it. do you think i can mix and match the internal gauge from the cx cluster?
Just to save me from posting it again, read this: https://honda-tech.com/zerothread?id=2014888
And as for the mixing and matching gauges, almost certainly not. You'd have to pop the needles off, disassemble the gauges, reassemble them correctly, and hope you got the needle in the right spot. I destroyed two gauges in vain when I tried it, but you may have better luck.
Re: gauge cluster swap question (qat727)
do you have glowing gauge faces? i saw a guy pop off the needles to install them before, and it screwed up his speedo and temp gauges.
