H22 swap wont start
H22 swap wont start
so attempted to finish a h22 swap on a 92 civic hatch, and the motor is in, conversion harness is put on, everything is fine, but the motor turns over and wont fire up. there was a weird buzzing noise coming from the main harness relay so i ordered a new one, plugged it in, and it made the same noise. the motor has spark since it pops with starting fluid, and it cant be the fuel pump because theres a brand new one in there. i am so confused on what is going on. any help with this would help guys.
Re: H22 swap wont start (93egB16A)
well only when you bypass the relay. otherwise when you leave the relay in it doesnt prime, but when you run a wire from the relay socket it primes but doesnt shut off. we tested another fuel pump also and it did the same thing.
y0whuddupb
31
08-09-2006 01:16 PM
y0whuddupb
07-31-2006 01:45 PM
Turbo_y8
03-05-2006 11:38 PM
