B16a2 Help
B16a2 Help
I just recently swapped a b16a2 into a eg coupe. My problem is once i reach vtec and shift "doesnt matter what gear" my car trys to stall out when i hit the accelerator, it literally pulls me forward and once it starts moving again it throws me back into my seat and it gets annoying after awhile and i cant figure out the problem. If i shift at a low rpm it doesnt do it as bad as when i hit vtec at a higher rpm and then shift. I also noticed when going about 80mph and I let off the accelerator and then step on it again it struggles to move "trying to stall out" and after a few seconds you feel the car speeding up again. Any suggestions?
Re: B16a2 Help (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">do you have a cel?</TD></TR></TABLE>
Indeed check for that and everything else too. A lot of the initial problems that come with a swap are simply from the person not triple checking that everything is secure, connected, and compatible with everything else.
Re: B16a2 Help (Hardedge)
no i dont have a cel code and everything is connected right, i have already had the connections looked at, ive been told it could be my tps but i guess ill find out tomorrow
vtek9
01-14-2008 09:38 AM
