Poor gas mileage?
Old 09-30-2007, 10:09 PM
DohctorVtec's Avatar
Default Poor gas mileage?
Hey guys, I am starting to get poor gas mileage on my 96 civic cx. It's the stock engine boosted with a Greddy 15g kit. The poor gas mileage just started a couple days ago. I filled up my tank on Friday, and now (Sunday) I have only driven about 92 miles and I am already at less than half a tank left. Any ideas on what would be causing this out of nowhere?
Old 09-30-2007, 10:13 PM
ke98248's Avatar
Default Re: Poor gas mileage? (DohctorVtec)
Did you just boost recently? How much are you boosting? I could be a number of things: clogged/stuck open fuel injectors, horrible tire pressure, old spark plugs/wires, fuel filter, etc...
You probably already know, but the Honda fuel gauges are notorious for being inaccurate.
Old 09-30-2007, 10:21 PM
forcefedferio's Avatar
Default Re: Poor gas mileage? (ke98248)
my car does this too...it's like random poor gas mileage.
as stated before check your plugs/wires replace fuel filter as needed. You know, go over the tune-up maintenance things.
Old 09-30-2007, 10:29 PM
H-T White Ops
Frozen E's Avatar
fuel leak?
Old 09-30-2007, 10:36 PM
kos99ngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">
You probably already know, but the Honda fuel gauges are notorious for being inaccurate.</TD></TR></TABLE>
like the EG6 also
Old 10-01-2007, 08:06 AM
Default Re: Poor gas mileage? (kos99ngel)
Ok, thanks guys. Also, what does it usually mean when your plug wires after driving for a while have pushed up. And are no longer securely pushed down over the little metal lip on the VC? I have never seen anything like that before.
Old 10-01-2007, 09:10 AM
BlkCivicFromTeamMNR.com's Avatar
I think i need to do all that!! lol I car hear when idle that i need sparks probably will get wires also....and I think imma need to do the fuel filter!! I have a 98 ex coupe how much of a pain in the *** is it to the fuel filter??
Old 10-01-2007, 09:15 AM
gsxr1k05's Avatar
i get the random shitty gas mileage too.. ususally on 85 octane i get 200 miles on a tank 95 civic dx stock. and when i tried 91 octane, i got 300.. i dont know... new fuel filter i think... but notice that when i top off, that i get the best milage... yes i know there is more fuel in the car.. but its still weird. is it the fuel guage or the sender that is inaccurate??? cause i would get an aftermarket guage if that was the problem.
Old 10-01-2007, 07:52 PM
H-T White Ops
Frozen E's Avatar
Default Re: Poor gas mileage? (BlkCivicFromTeamMNR.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkCivicFromTeamMNR.com &raquo;</TD></TR><TR><TD CLASS="quote">I think i need to do all that!! lol I car hear when idle that i need sparks probably will get wires also....and I think imma need to do the fuel filter!! I have a 98 ex coupe how much of a pain in the *** is it to the fuel filter??</TD></TR></TABLE>
Get a brake line wrench to do the nut on the fuel filter. Those damn things are on there TIGHT, and if you're not careful you can strip it using a regular wrench.
Other than that it's cake. Couple of 10mm bolts and you're set. Fuel filter SHOULD be right there on the firewall next to your battery.
Old 10-03-2007, 08:35 PM
Default Re: Poor gas mileage? (IslandSi)
O ok thanks man.... It sounds easy enuff...for some dumb *** reason I thought I had to drop the gas tank or sumething Dumb!! lol....But thanks for the info
Old 10-03-2007, 08:42 PM
ke98248's Avatar
The fuel filter replacement on a 6th gen civic is the easiest thing ever... Just pop off the gas cap to de-pressurize the fuel system. Then place a catch can or towels under the fuel filter/fuel lines going to the filter. Take off the lines connecting to the filter and the bracket to the filter. Replace and reverse the steps. Should only take 20 minutes.
Old 10-04-2007, 01:01 AM
ToFFoo's Avatar
i hate the honda fuel gauges
Old 10-04-2007, 07:37 PM
H-T White Ops
Frozen E's Avatar
Default Re: (ToFFoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToFFoo &raquo;</TD></TR><TR><TD CLASS="quote">i hate the honda fuel gauges </TD></TR></TABLE>
Yep. long sweeping right hand turn (like an on or off ramp) I'll "lose" 1/4 of a tank.
FWIW, I just replaced my distributor a few days ago and I noticed about a 40 gallon/per tank increase. Of course my last distributor was shitty and made the car sputter like crazy. I was getting around 210 miles per tank before I put the new distributor in.
Old 10-04-2007, 07:48 PM
Jonathan_ED3's Avatar
400+++ on a tank here. 45mpg FTW!!! bone stock with 230,000 miles.
Old 10-04-2007, 08:25 PM
ke98248's Avatar
Default Re: (Jonathan_ED3)
lol, nice! Are you proud to be one of the many slow but proud?
Old 10-05-2007, 07:37 AM
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">lol, nice! Are you proud to be one of the many slow but proud?</TD></TR></TABLE>
Yep. People don't realize gas mileage is related to driving technique.
I know guys that only manage to get 20mpg out of DX's. It's because they drive 80mph on the highway, drive aggressively shifting at 4k rpm everytime etc. That KILLS your mileage!!!
jcarrollr
Honda Civic (2001 - 2005)
03-16-2013 02:44 AM
Seanith
08-07-2005 04:41 PM
xfrankx
01-27-2005 09:12 AM
dropd4door
12
09-13-2004 07:10 AM
nver2
02-03-2004 01:27 PM
Quick Reply: Poor gas mileage?
