about an engine swap.
well i blew my y8 yesterday
and i'm looking at getting a d15b
i have a 97 ex.
Engine
Transmission 5-Speed LSD
Distributor
Alternator
Starter
A/C Compressor
Power Steering Pump
Intake Manifold
Exhaust Manifold
Throttle Body
Clutch
Fly Wheel
Pressure Plate
thats what comes with the engine.
would i be able to use my motor mounts from my y8?
and would it wire up to my ecu or would i have to get a different ecu since
a d15b is obd1 and my ecu is obd2?
sorry i'm not that intelligent when it comes to this.
can yall help me out a little?
i have a 97 ex.
Engine
Distributor
Alternator
Starter
A/C Compressor
Power Steering Pump
Intake Manifold
Exhaust Manifold
Throttle Body
Clutch
Fly Wheel
Pressure Plate
you can get it to work, but you might as well get ready for the obd1 ecu or you will throw a code nonstop.
I put an obd2 oil pump in my z6 so that would work, you might want to look into doing that.
Re: (Jakester9500)
u can use everything from your stock motor and you need to get an oil pump with the crank sensor on it so you wont throw a code for that. and just use all of your stock mounts
wevtech
03-12-2011 12:46 AM
northkai3
15
08-30-2006 09:11 PM
