Replaced the o2 sensor but still throwing code.
Old 09-30-2007, 08:24 AM
importdreamer's Avatar
Default Replaced the o2 sensor but still throwing code.
I threw a cel of 61 (or 71) either way it was the one for the primary o2 sensor. I went on sparkplugs.com and bought a denso direct replacement sensor. Got underneath there and replaced it with no problem. After that I took the negative battery cable off for about 3 minutes and replaced it. I drove it about 80 miles and the check engine light came back on.
What is the easiest way to check the wires on the plug? Because all i can think of is that I pulled on the harness too hard while removing the old one.
By the way its a 00 si
Modified by importdreamer at 11:38 AM 9/30/2007
Old 10-03-2007, 05:44 AM
accord2nrz's Avatar
a voltmeter i would imagine
Old 02-02-2008, 07:20 AM
CooBlueDAB's Avatar
Default Re: Replaced the o2 sensor but still throwing code. (importdreamer)
I had the same problem, at the same time... but a 99, I am thinking wiring, anyone have any specifics on where to look?
Old 02-02-2008, 09:55 AM
Default Re: Replaced the o2 sensor but still throwing code. (CooBlueDAB)
Actually the problem fixed itself. It comes on and off every now and then. I have an exhaust leak about 2 inches from the o2 sensor. I think that had something to do with it. Sorry I can't help you.
vtec2nv
04-12-2013 04:52 AM
Koyoloeor
10-13-2005 04:57 PM
vtec-adykt
09-12-2005 01:09 PM
apok
05-16-2005 09:52 PM
89Si
04-21-2002 07:24 PM
Quick Reply: Replaced the o2 sensor but still throwing code.
