Which Distributor fits
Does anybody know which distributor would fit my jdm b16a obd1???? i know a delsol cap and rotor will fit but i want to know which distributor would fit, thanks alot...
Re: Which Distributor fits (malo11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malo11 »</TD></TR><TR><TD CLASS="quote">Does anybody know which distributor would fit my jdm b16a obd1???? i know a delsol cap and rotor will fit but i want to know which distributor would fit, thanks alot...</TD></TR></TABLE>
to make things easy,
the b16 from a 94-95 del sol.
the b18 from a 94-95 integra gsr.
any jdm one from 92-95 civic/integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malo11 »</TD></TR><TR><TD CLASS="quote">so a del sol dohc distributor would fit??</TD></TR></TABLE>
yes, but it has to be from a dohc b16a3 94-95 del sol.
Re: Which Distributor fits (philosofy1)
oh ok,..thanks alot man, that heps alot, now do you know if the distributor has anything to do with my revolutions and tachometer not working???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malo11 »</TD></TR><TR><TD CLASS="quote">oh ok,..thanks alot man, that heps alot, now do you know if the distributor has anything to do with my revolutions and tachometer not working???</TD></TR></TABLE>
if the ,otor is working fine, then i want to say either there is a break from the dist to your tach, or your tach is bad.
I dont think my tach is bad because it was just working on my way to the mechanic before he took off the distributor, but the distributor has a leak and i wasnt able to buy a new one right away so he put it back, it doesnt even fit my block, its being held on by just one bolt and its not sealed right as it should be, when he put it back, and i started my car, tach wasnt working anymore..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malo11 »</TD></TR><TR><TD CLASS="quote">I dont think my tach is bad because it was just working on my way to the mechanic before he took off the distributor, but the distributor has a leak and i wasnt able to buy a new one right away so he put it back, it doesnt even fit my block, its being held on by just one bolt and its not sealed right as it should be, when he put it back, and i started my car, tach wasnt working anymore..</TD></TR></TABLE>
sounds like a half *** mechanic. if i was you i would take it back and tell him your tach isn't working after he touched it, and also he should bolt on the dist. better, or with one that you're supposed to have.
yea but i bought that swap from a guy about a yr ago and he had the set up with that distributor already,...the mechanic was going to replace it but i wasnt able to buy the correct distributor for it at that point so he put the same one back,...
malo11
10-16-2007 07:03 AM
prjctCIVIC
03-19-2002 08:04 PM
