(help need) i dont have a jumper harness is there any other way to check for codes
i have a 92 dx civic hatchback that is in limp mod and there is no jumper harness on it is there a eather way to check why it is in limp mod can some-one help me
Re: (Kegan)
so what dose dizzy mean is just a code b/c i have a b16a with a d16/y8 distrubutor but it fired up the car and everthing so i though nothing about it seem everthing was right you no
Re: (Kegan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kegan »</TD></TR><TR><TD CLASS="quote">Limp mode usually means ditributor. </TD></TR></TABLE>
...What You could be throwing any number of codes that throws the ecu into "limp" mode.
bottom of this thread:
https://honda-tech.com/zerothread?id=2029482
http://technet.ff-squad.com/wiring.obd1.htm
Re: (pdiggitydogg)
like i looked where it should have been but it is not there and i dont no what to do i have the pin out schematics but now what do i do?
Just find the wire on the ECU to trip the self diagnostic and ground it. You dont need just the jumper.
EDIT: pdiggitydogg did all the work for you, its the white wire on pin D4 ground it.
And dont listen to the guy who said it was the distributor. CEL's rang from 100's of thing, distributor is only like 5 of them. Also dont throw parts at it, figure out whats wrong first then fix it right, dont just throw a new distributor on unless its causing the problem.
Re: (pdiggitydogg)
so just ground out the d4 with is the scs service check single now dose it matter what i ground it to or is this not right b/c that is what you guys made it sound like
Re: (Max Kling)
hell yea i have so much money in parts that i dont even need just bought a new ecu for my b16 i had a chipped skunk2 p28 but now i have a stock b16 ecu and you no how much they can be not to cheap tired of spending money on **** that dont fix it
hotxcivic92
10-01-2007 07:55 AM
