car boggs at 4,600 rpm's
ok its a 94 civic with a d5z1 in it and it boggs out at 4600 hes tried difeerent ecus but no go we've checked grounds,and timing is there n e thing else that we can check....can it mayber be the fuel filter...it revs to 5,100 at idle but wen driving only 4,600 rpm's...so we need help kind of out of ideas.so can you help us.thnx ahead of time
Re: car boggs at 4,600 rpm's (beatthisspeed69)
Fuel filter is on back wall, next to battery(passnger side). It's not fuel filter. Check ecu or injectors? Sounds like its running rich. When I swapped out stock injectors and chipped ecu, mine did same thing. Could get decent rpms in neutral, but soon as I drove it around the block it just chugged away. Had to throw in the fpr before I could drive it.
BlueIntegraBoy
06-08-2011 06:15 PM
