need hlp how to add pressure to clutch
Re: need hlp how to add pressure to clutch (purp_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purp_ek »</TD></TR><TR><TD CLASS="quote">want to know how to add more pressure to my clutch
need help urgent plz </TD></TR></TABLE>
New Racing Clutch
New Racing Clutch
you can flush your clutch fluid and then bleed it. It might help if your brake fluid in your clutch like has taken on to much mosture and compressing more then it should.
Re: need hlp how to add pressure to clutch (Colby71)
bigger master cylinder!! omni power had many problems in the past... they said they fixed it last time then recalled it again. go stock. or get a race clutchx2. bleed the fluid x2... oops.. i think i was thinking brake master cyl..
Modified by mastakmk at 8:46 PM 12/4/2007
What he means is wants a stiffer foot peddal which you would go about doing by bleeding the clutch master cylinder line which is located on front of bellhousing on tranny with little nipple like end to it.
Re: need hlp how to add pressure to clutch (SEATownboi08)
That actually would be the slave master cylinder. The Clutch master cylinder in located on the firewall just next to the brake cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEATownboi08 »</TD></TR><TR><TD CLASS="quote">What he means is wants a stiffer foot peddal which you would go about doing by bleeding the clutch master cylinder line which is located on front of bellhousing on tranny with little nipple like end to it.</TD></TR></TABLE>
if its not gettin pressure, go get a new slave master cylinder,... or mayb, ur out of fluid,
