skunk2 mani, and 68 mm tb issues
pulled the motor out of my crx working fine.....idle was a bit high about 1000-1200 but no big deal... bought a 94 coupe with b16 had a blow head gasket and need a clutch so i just pulled motor tranny and all. my the new clutch on my motor bolted the tranny up and back in the car. i put a new tsp senor on and ajusted it. the car wont idle correctly it idle hops and studders i bit. only one cel which was on before i swaped motors and came on once i started the car with my motor code 14 i believe iacv but i didn't have the code before in my crx. maybe wiring, maybe my tb and mani, can anyone help...i'm new to this obd1 stuff.
thank for any help
thank for any help
Re: skunk2 mani, and 68 mm tb issues (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Wow, can you say "overkill"
Use at the most a 60-62mm tb. 68 is gigantic.</TD></TR></TABLE>
not to be rude but how is it over kill work great in my crx. i just had a aem fpr,skunk2 mani, 68mm tb, with y1 lsd tranny, stage 3 6puck, and pulled a 13.8
Re: skunk2 mani, and 68 mm tb issues (93egSLEEPER)
no leaks that i know of. skunk 2 tb have no vaccum hose... just ur pbc vavle from the mani to the block and one to the fpr.
theres 3. one on the back its pluged.... it s emissions stuff, on to the fpr, and one to the pvc valve. i'm almost 100% sure theres no leaks. would the code have any thing to do with it.
Re: skunk2 mani, and 68 mm tb issues (si90rex)
i had my tps come loose before and it made it idle like it was missing a cylinder... what kinda idle problem is it exactly?
fast hop......800-900 i tried the dizzy but that didn't help. ajusted the tsp all that did was make it rev up on its own didn't help either. the skunk2 tb has no vaccum hoes and no fast idle valve that idle is all mechanical. just the iacv.
crap alright thanks for the help ill call skunk2 tomorrow see wtf is going on..... thanks
Ep1dem1c
07-18-2007 10:03 AM
Varao
04-11-2006 08:24 AM
