step on brake pedal rpms raise help
so i step on the brake pedal while the car is tryin to start and the rpms raise also the rpms raise if i turn the headlights on and the car has no spark. seems like no one can figure this out! any help much appreciated
Modified by terribl3jon at 7:42 PM 12/5/2007
Modified by terribl3jon at 6:36 PM 12/22/2007
do you understand the "car has no spark" term?
this would imply that the car won't start...
so the question is, how can your rpm's rise, if your car won't start.
knowing now what "no spark" implies, lets restate your question....
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">do you understand the "car has no spark" term?
knowing now what "no spark" implies, lets restate your question....</TD></TR></TABLE>
while im TRYING to start my car if i step on the brake pedal my tach will move up as if the i were revving the motor. does that help you?
Re: step on brake pedal rpms raise help (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">How do the RPMs increase if you have no spark?</TD></TR></TABLE>
so simply put the needle of tach moves when i step on the brake pedal yet the motor is not running
Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic »</TD></TR><TR><TD CLASS="quote">bad distributor is likely</TD></TR></TABLE>
i used my friends dizzy out of his working car cso i thought that was the problem
What about over working the brake system? Just like on power steering, if you use an accessory won't it chage the rpms? I could be wrong as this may be for only belt driven acessories but I know the volatge of a battery can even affect the rpms.
I guess we should be asking how much it raises when you press the pedal. But is the car even on when this happens? If not sounds like wiring, I did a cluster swap and had a few pinouts wrong and my gauges were all crazy.
Re: step on brake pedal rpms raise help (JDM_Frijoles)
well the main problem is that the car doesnt have spark lol. i just thought it was weird about the brake thing and maybe had something to do with it. im assuming that i have a wiring issue
