rear disc brake conversion
yes i know another one of these.
i drive a 94 civic ex coupe
ok so i bought a conversion on here from somebody on here.
anyways i was told they were off a sir2. but after closer inspection it looks like they are off of a crx si.
now my question is will these work? will they bolt up correctly? will the ebrake cables be the right length?
is the size of the caliper and rotor smaller or the same size as the ones off of a hatch si?
are the trailing arms even the same?
thats all i can think of at this second i will probably be back with more questions. thanks
Re: rear disc brake conversion (BlueIntegraBoy)
So JDM EG lower control arms are different than US lowers? explain why suspension set up is identical between JDM and US, when the control arms are different
Re: rear disc brake conversion (sohctodohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc »</TD></TR><TR><TD CLASS="quote">So JDM EG lower control arms are different than US lowers? explain why suspension set up is identical between JDM and US, when the control arms are different</TD></TR></TABLE>
Yes, the EG6 LCAs are similar to the ITR LCAs.
vtec-adykt
01-27-2005 07:13 PM
B16EJ
01-04-2005 09:32 AM
igo4bmx
11-21-2003 07:13 AM
