losing fluid in the hydralic clutch cylinder
hey guyz. i need some advice or help.. one time i was driving my civic to work, all of a suddenly the clutch didnt wanna go in. so i went to go check an i was out of hydraulic fluid. when i add more, everything works fine, ...as i drive it again, same thing happen. so i bleed it over an over again,,, so i got fed up wid it, an went to go purchase a new clutch slave cylinder, an that fix all the problem.... like 4 to 5 days later.. i pop open my hood, due to oil change, the hydraulic fluid is all out, im like wtf,,, i check ever no leaks,.... an im all out of ideas. any body ?>????? got thee answer. an advice,>>??? would b appreciated
Re: losing fluid in the hydralic clutch cylinder (ej1-usdm)
Gennerally you replace the master and slave cylinders at the same time as they wear out together. Check your clutch master cylinder. I bet its leaking down the firewall.
GraphiteMW
03-25-2007 09:26 AM
malubawla
10-16-2005 04:16 PM
