shaking/vibrating in passenger wheel.......
what up i got a problem........i have pretty bad shaking/vibrating in my steering wheel feels like its coming from my passenger front wheel i just changed the axle its all good got my wheel balanced and checked for the wheel hub by movin the tire and checking for it to wobble everything seems to be ok so i dont know what is causing it...hopefully maybe just a simple alignment or something else...input please
Re: shaking/vibrating in passenger wheel....... (96lsivtech)
the bolt on your lower ball joint might be loose. i realized too late when the whole thing fell apart on me taking a turn.
check to see if you tie rod ends are not loose..happened to me got a new one and had it adjust to make the wheel straight and everything was good..but yeah i would suggest taking it to shop to see what really needs to be done good luck.
Re: shaking/vibrating in passenger wheel....... (ek-g6)
now it seems to fo gotten worse feels like my steering is loose and it pulls when i let go of the wheel somtimes
moonchies
04-06-2018 09:57 AM
