Clockspring question
had no search results for this. long story short replaced my ignition switch and had to pull steering wheel off to get to those damn "break to torque" bolts. when i did i decided to pull the wheel off without a puller and just muscled it off and the clockspring came out and now needs replacing due to it coming out and unwinding. can someone please tell me why it unwinding caused my srs light to come on. no wires were hurt in doing these things.
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
Man that sucks.
I replaced my ignition once, because of a snap key.
I didnt remove my steering wheel, because i was to lazy.
Can you re-wine it back? What is a clock spring? Im so dur dur...
clock spring is that ribbon like thing behind ur steering wheel that gives ur airbag power and ground. what did u do to remove your ignition switch? didnt u have those headless bolts to remove? i had to dremel a slot in them and use a flat head to get them out! couldnt fit it in there without removing the steering wheel =*(
Re: Clockspring question (mav87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mav87 »</TD></TR><TR><TD CLASS="quote">had no search results for this. long story short replaced my ignition switch and had to pull steering wheel off to get to those damn "break to torque" bolts. when i did i decided to pull the wheel off without a puller and just muscled it off and the clockspring came out and now needs replacing due to it coming out and unwinding. can someone please tell me why it unwinding caused my srs light to come on. no wires were hurt in doing these things.</TD></TR></TABLE>
Broke connection - the clockspring is the power/grnd to your airbag, with a break in that circuit the SRS light will come on as the ECU knows that the airbag will no longer function.
PhrequenC
14
02-01-2008 11:29 AM
ek9tl
02-22-2007 10:34 AM
active_motorsports
02-24-2004 10:35 PM
