Screeching noise when driving from wheel area
Old 12-28-2007, 10:03 AM
KHowe's Avatar
Default Screeching noise when driving from wheel area
I have a problem coming from what seems to be the front passenger side. It's a screeching noise when driving, and sounds like metal on metal. My initial thought was the rotor rubbing against the brake dust shield (unsure if thats what it's called). I took a prybar and tried bending the dust shield back (this fixed a previous problem I had on the other side), but it hasn't fixed it.
The problem gets loud and quiet off and on, but its always there. It used to go away for a few seconds if I tapped the brake, or occasionally if I turned the wheel a bit. It now seems to be pretty constant regardless of what I do. Please help, it's made my car unbearable to drive (as well as pretty embarrassing when pulling in anywhere). Thanks in advance.
Old 12-28-2007, 10:29 AM
KHowe's Avatar
Default Re: Screeching noise when driving from wheel area (KHowe)
Could this be brake pad indicators?
Old 12-28-2007, 03:49 PM
EJ8mike's Avatar
You probably have a rock stuck in-between the dust shield and rotor. It has happened to me a few times before. Eventually the rock just works itself outa there or it gets grinded down to smitherines.
Old 12-28-2007, 03:52 PM
EJ8mike's Avatar
Default Re: Screeching noise when driving from wheel area (EJ8mike)
could be your brake pad indicators too, check them out
Old 07-16-2010, 05:26 AM
corsair37's Avatar
I know this post is 2 1/2 years old, but this is the only post I could find that is having the same problem I am having with my 2003 CRV. Can you tell me what the problem ended up being? Thanks!
Old 07-16-2010, 05:37 AM
blaze_125's Avatar
wheel bearing?
Old 07-16-2010, 07:43 AM
WeakSauce92's Avatar
I've got a similar problem..
Old 08-02-2010, 12:06 PM
corsair37's Avatar
I finally got my car fixed. It was the rear brake pads, they were almost gone. The rear rotors were also warped. I wasn't thinking breaks since I just had them relaced 14 months ago, so I must ride my brakes
b20acura
06-28-2011 12:20 PM
thavarin
07-02-2007 02:55 PM
GUNNER666
08-08-2004 12:06 PM
magic hat #9
02-21-2002 05:21 PM
GoLowDrew
11-06-2001 05:18 PM
Quick Reply: Screeching noise when driving from wheel area
