b16 differences
b16 differences
I'm interested in a b16 but I'm not sure which one would be best.... I have a 98 hatch.... don't really know if a b16a2 or b16a1 would be better.... also better to go USDM or JDM.... would be greatly appreciated if someone could help me out
p.s. I already used that big red button in the sky
Re: b16 differences (kevo1586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevo1586 »</TD></TR><TR><TD CLASS="quote">I'm interested in a b16 but I'm not sure which one would be best.... I have a 98 hatch.... don't really know if a b16a2 or b16a1 would be better.... also better to go USDM or JDM.... would be greatly appreciated if someone could help me out
p.s. I already used that big red button in the sky </TD></TR></TABLE>
As BlueIntegraBoy said, an OBD-II B16 would be best for an OBD-II chassis, less wiring.
B16A1 = OBD-0 = < '92
B16A3 = OBD-I = '92-'95
B16A2 = OBD-II = '96-'00
Yours is a '98, so get the B16A2, and I think you have to change the dizzy plug, but that's all (I think).
Also, you'll need an OBD-IIa to OBD-IIb conversion harness so your ECU plugs in.
Most of the other crap (wiring wise) will be the same.
PS:
It's better to go JDM, they have a slightly higher compression ratio so you'll have a bit more power (The USDM B16A2 is rated at 160bhp while the JDM model, the B16A, is rated at 170bhp.
BUT
(wait for somebody else to confirm this)
I'm pretty sure the SIR-II (JDM B16A) is an OBD-I motor, which means you'll have to do a bit more wiring wise (nothing heavy), so take your pick from there. You have to wire up the distributor, injectors, and alternator plugs to make it happen, other than that, no big difference, and I'm not even positive if the JDM B16A was OBD-I or not.
PS:
BUT
Re: b16 differences (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
I'm pretty sure the SIR-II (JDM B16A) is an OBD-I motor, which means you'll have to do a bit more wiring wise (nothing heavy), so take your pick from there. You have to wire up the distributor, injectors, and alternator plugs to make it happen, other than that, no big difference, and I'm not even positive if the JDM B16A was OBD-I or not.</TD></TR></TABLE>
The JDM b16A SIR-II is an obd-II motor... Im pretty sure that there is an OBD-0 OBD-I and OBD-II JDM B16A
Re: b16 differences (civicb16eg)
basically from what i gather you have to decide if you want to convert to OBD1 or stay with OBD2. IMO OBD1 is much easier to work with and typically has less problems with emissions,CELS, etc. if you could get a complete SI swap (b16a2) then id go with that but if your trying to just piece a swap together (JDM block, A2 head etc.) id go OBD1. Im running JDM block and bottom end (10.4:1 CR as compared to USDM 10.2:1 CR) with a 00 Si head and IM but ran OBD1 chippied p28 on chrome and its badass. all depends on how you wanna do this bad boy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg »</TD></TR><TR><TD CLASS="quote">
The JDM b16A SIR-II is an obd-II motor... Im pretty sure that there is an OBD-0 OBD-I and OBD-II JDM B16A </TD></TR></TABLE>
@ OP:
Welp, then there ya go, JDM B16A (OBD-II) would be your best bet.
If you wanted to stay USDM (for whatever reason):
B16A2 is our OBD-II engine.
@ OP:
PS:
BUT
If you bought an OBDI or 0 for your OBDII car you would have to change the ecu, harness, injectors, distibutor and the altornater.
The b16A is the jdm model, It came with P30 piston that increased compression that resulted in the 170hp instead of the USDM's 160. Also the B16A did come in all OBD modles as it was offered in other countrys since 1980 threw 2000.
But the only difference in the b16A to the USDM b16 was the pistons.
All the other B16's A1 A2 A3 are usdm model and there the difference ia only the OBD.
Hope this help. I ran into the same question with one of my swaps back in the day.
G/L
PS:
BUT
G/L
Re: b16 differences (EKstacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg »</TD></TR><TR><TD CLASS="quote">The JDM b16A SIR-II is an obd-II motor... Im pretty sure that there is an OBD-0 OBD-I and OBD-II JDM B16A .</TD></TR></TABLE>
wait i thought the Jdm Sir-II was obd1? being that in came in the sir from 92-95 and that the p30 ecu that comes with that motor is obd-1
Re: b16 differences (mini-meEj1)
The OBD's very just like they do here. Use your knowledge of the usdm's of odb and it's the same for JDM's. Just go with the year motor for your car. It's less work. I used a obd 0 block and a obdII head and changed them both to OBDI for my setup. Just get what you need for your car.
ok, there has been a confusion here. the B16A SiRII is an OBD1, because i have it in my sedan. the body is a 93 civic and it bolted on easily, no conversions necessary. if you want to swap without headaches, get the USDM B16A (from the 2000 Si), that is an OBD2. but you can always put an OBD1 and OBD0 on your OBD2 car if you like
Resident Gearhead
Re: (devney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devney »</TD></TR><TR><TD CLASS="quote">B16A SiRII is OBD1.</TD></TR></TABLE>
Yes, yes it is. Anyone who says different - GTFO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">It's better to go JDM, they have a slightly higher compression ratio so you'll have a bit more power (The USDM B16A2 is rated at 160bhp while the JDM model, the B16A, is rated at 170bhp.</TD></TR></TABLE>
You are right about the CR part.
And too that dude out there that fought with me saying "all B16A's have the same CR no matter what DM they're from" shut the hell up and learn before you speak.
Re: (mcvtec)
B16A
Note: All JDM OBD0 B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
VTEC
Found in:
1988-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1991 JDM Honda CRX SiR (EF8)
1989-1991 JDM Honda Civic SiR (EF9)
Displacement: 1595 cm³
Compression: 10.2:1
Rod/stroke ratio: 1.74
Power: 158 hp @ 7600 rpm & 111 ft·lbf @ 7000 rpm
Transmission: S1/J1/Y1/YS1
1992-1995 JDM Honda Civic SiRII (EG6/EG9)
Compression: 10.4:1
Power: 170 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
Transmission: S4C
1992-1996 JDM Honda CR-X del Sol SiR
Compression: 10.4:1
Power: 158 hp - 167 hp & 111 ft·lbf - 116 ft·lbf
B16A1
VTEC
Found in:
1990-1991 EDM Honda CRX 1.6i-VT (EE8)
1990-1991 EDM Honda Civic 1.6i-VT (EE9)
Bore×Stroke: 81.0×77.4 mm / 3.19×3.05 in
Compression: 10.2:1
Power: 150 hp @ 7600 rpm
Torque: 144 N·m / 106 lbf·ft @ 7100 rpm
Transmission: Y2
B16A2
VTEC
1992-2000 Honda Civic EDM VTi (EG & EK)
Compression: 10.2:1
Power: 158 hp @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21
1999-2000 Honda Civic Si (EM1)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 S4C
Bore: 81mm
Stroke: 77.4mm
B16A3
VTEC
Found in:
1994-1995 Honda Del Sol VTEC (EG)
Compression: 10.2:1
Power: 158 hp (118kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21
B16A4
VTEC
Found in:
1996-2000 Honda Civic SiRII (Asian version) (EK)
Compression: 10.4:1
Power: 170 hp (127kW) @ 7800 rpm
B16A6
VTEC
Found in:
1996-2000 Honda Civic - South Africa VTEC (EK)
Compression: 10.2:1
Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21
Cheers.
VTEC
Found in:
Compression: 10.2:1
Compression: 10.4:1
Transmission: S4C
Compression: 10.4:1
B16A1
VTEC
Found in:
Compression: 10.2:1
Transmission: Y2
B16A2
VTEC
Compression: 10.2:1
Transmission: Y21
Compression: 10.2:1
Bore: 81mm
Stroke: 77.4mm
B16A3
VTEC
Found in:
Compression: 10.2:1
Transmission: Y21
B16A4
VTEC
Found in:
Compression: 10.4:1
B16A6
VTEC
Found in:
Compression: 10.2:1
Transmission: Y21
Cheers.
Resident Gearhead
Re: (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">Note: All JDM OBD0 B16A engines are stamped 'B16A' (with no number after the "A" to identify version).</TD></TR></TABLE>
Except, I'm pretty sure, that ALL OBD JDM B16A's are stamped "B16A" with no suffix #. I have an OBDI JDM B16A and it is stamped "B16A".
Re: (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">
Except, I'm pretty sure, that ALL OBD JDM B16A's are stamped "B16A" with no suffix #. I have an OBDI JDM B16A and it is stamped "B16A".</TD></TR></TABLE>
Indeed. All JDM B16A's have no # designation. There's just B16A & B16B, no #'s.
Re: b16 differences (93egSLEEPER)
The 92-95 JDM B16A2 out of the SiR II EG6 chassis is an OBD1 engine as the serial # will testify. starts with a 1 it is OBD 0, starts with a 5 it is OBD1.
Thanks everyone for the info.... I would like to go OBD-II if poss.... but even if I decide to go OBD-I, I don't have to worry about smog.... Canada
The year of the motor doesnt matter. The outside parts is what makes the diffrence. Im running a obd0 b16 and it was so easy to put in my 96 coupe. I used my stock injectors, B-series alternator, and obd2 distributor. Than, just ran two wires to my Obd1 ecu.
